2026-09-15 03:33:10
432
24
16-28mm Pipe Routing Clips | Snap-Fit M3
@MateuszTokarz_4351639
BOM: Printed with ROSA3D High Speed PLA Dark Blue
Scaling up our popular cable and tube clips! This heavy-duty set of snap-fit pipe brackets is designed for much larger routing tasks. They perfectly accommodate standard PVC plumbing, copper water lines, vacuum hoses, and thick electrical conduits.
Just like the smaller versions, simply drive a screw through the central mounting hole into your wall, stud, or workbench, and firmly press your pipe into the bracket. The arms will flex open and aggressively snap shut, locking heavy, rigid pipes securely in place.
Key Features:
  • Heavy-Duty Sizes: The set includes perfectly toleranced clips for 16mm, 18mm, 20mm, 22 mm, 25mm, and 28mm pipes.
  • Secure Snap Action: The thickened retaining arms hold heavy pipes firmly while still providing enough flex to snap them in and out.
  • Standard Mounting: Features a central mounting hole for quick, secure attachment using standard screws.
  • Clear Labeling: Never guess which clip you are grabbing—the exact pipe diameter is embossed directly onto the front face.
3d
wall
functional
holder
clip
mount
diy
pipe
bracket
snap
hardware
workshop
plumbing
organization
tools
copper
wire
conduit
pvc
routing
